It is currently Tue Sep 25, 2018 5:52 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: room/sound panels.
PostPosted: Fri Apr 08, 2016 8:03 am
allgonoshow wrote:
drummermitchell wrote:
I don`t believe foam does much of anything for the low end
Personally would not touch that stuff
1000% better off with OC 703-or 5
So, what do you do with the OC stuff?
Looks like raw material fiberglass.
It is better or different than Roxul, which is more commonly available.
Do you build a frame around it, cover it fabric?
Any pics?
Every material is different in terms of absorption coefficients over different frequencies. OC 703 has been tested and the absorption tables are widely available. I'm sure there is a comparison table somewhere with Roxul showing which one works better, etc.
Regarding the original comment - yes, *thin* foam does not do anything to low frequencies. You need deep chunks of good absorbing foam or whatever insulator you use to provide proper absorption for low frequency waves (<~80Hz)
