It is currently Mon Jul 16, 2018 11:55 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sat Jan 21, 2017 2:53 pm
dcrooks wrote:
Teo Audio wrote:
The kind of device that does such things, tends to be the analog alps digital stepper control.
It has a track divided into two, an inner and outer..and each track is offset from the other.
Since it is actually almost the same design as a standard analog volume pot, they wear out.
Really? The consumer units are mechanical? I've worked with these sorts of encoders in a lot in mechanical gear, they've all been optical, with a glass plate with an etched chrome plating on one side, in the pattern you describe, that blocks the light between an LED and a photo diode. No wear... Only the occasional LED or diode failure, but generally they last decades of 24/7 use.
Sounds like something a retrofit kit could be built to cure!
Cheers, Dave
and its not just consumer units. more than one way to get a pulse....with less parts. and like you said there still will be the odd led or diode failure.
-- 21 Jan 2017 22:54 --
Prestige wrote:
Cambridge has well documented issues with volume controls and lasers failing in their cd players.
Take care stinkydinkythecat.
any links to these documents?
PostPosted: Sat Jan 21, 2017 2:55 pm
Just to be clear, the Xindak uses an Alps control.
PostPosted: Sat Jan 21, 2017 3:00 pm
waxwings wrote:
Bad news:Typical problem with Cambridge Audio receiver's volume control. The grease the factory uses is not dielectric :roll: and can cause the control to run amok usually after a short time in service.
Good news: A tech can disassemble the control clean it out then use the correct lubricant and Bob's your uncle!
Really?! if the grease was conductive what do you think the end result would be?
the issue is due to the hardening of the grease.
here's a video how one works https://www.youtube.com/watch?v=v4BbSzJ-hz4
grease globs fracks the signal.
this is not just a Cambridge issue.
PostPosted: Sat Jan 21, 2017 3:17 pm
-- 21 Jan 2017 23:22 --
but one usually thinks quality when alps is mentioned?
PostPosted: Sat Jan 21, 2017 3:52 pm
I agree with you, but every "famous ", manufacturer has quality issues from time to time.
