It is currently Sun Jul 15, 2018 7:01 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Jun 26, 2017 2:27 am
Peek cleaner in a tube is great for metal surfaces
ALCOA aluminum heavy duty polish
-- 26 Jun 2017 10:30 --
Make up brush for dusting tight areas
PostPosted: Mon Jun 26, 2017 3:11 am
On wood....Lemon oil.
On metal, Mother's car wax.
Daily dusting....when I remember.
Cheers, del Sol
PostPosted: Mon Jun 26, 2017 3:51 am
For high-gloss piano black speakers (which I own) I clean and polish with the same trusty product I have been using on my piano for 25 years: Cory Piano Polish. They also make a fine-scratch remover.
https://www.google.ca/search?q=cory+pia ... LXYZVkg18M:
For anything wood I use Dunlop 65 guitar cleaner and polish. Been using this also on my guitars for 25 years...
https://www.google.ca/search?q=dunlop+6 ... N2jiFyPF0M:
Those products won't harm delicate musical instruments, let alone hifi gear.
PostPosted: Mon Jul 03, 2017 4:47 pm
buddha wrote:
Nope. need something stronger unfortunately.
Post a pic for help.
Try the alcohol just in case but it likely won't work.
I actually removed the faceplate and soaked it in dish soap / water and then took a soft sponge and scrubbed down the plate - took the marker right off and whole thing came out looking brand new!
PostPosted: Mon Aug 14, 2017 4:37 pm
stefanb wrote:
Anyone know the best way to get marker writing marks off a Marantz faceplate? Would rubbing alcohol work?
If know that a dry erase marker removes Sharpie black from whiteboards. Not sure about how the plate would react with the dry erase......
