> Classifieds > > > McIntosh MC-502 Power Amplifier 50wpc - 150w in mono - Cracked Faceplate
SOLD - FOR SALE: McIntosh MC-502 Power Amplifier 50wpc - 150w in mono - Cracked Faceplate
Item #649444256
Info: McIntosh MC-502 Power Amplifier 50wpc - 150w in mono - Cracked Faceplate
USD $399.00
Retail Price: USD $1495.00
Payment method: Paypal
Ships to: United States
Shipping weight: 13.61 (kg) Calculate Shipping
Condition: 7 - Good (?)
Date Posted: Jun 17, 18 6:04pm (PST)
Edited: Jun 30, 18 9:54am
About Seller: CA, United States
PayPal:
Days in System:13
Up for Sale is a McIntosh MC-502 Power Amplifier. Other than the cracked faceplate which occurred during shipping, the unit is in very good operational and cosmetic condition. It is being offered for sale at a reduced price due to the cracked faceplate. The unit was serviced and brought up to specifications in January of 2015 by Classic Audio. This Model is 50wpc (8ohm) and is switchable to a 150wpc mono. With the front panel line level inputs, it makes for an excellent quality CD or Headphone amplifier. If hidden away as a center channel amplifier, the faceplate would not be of importance. If the appearance is important, it would cost about $200 to have the faceplate replaced. FREE SHIPPING to USA This is a good opportunity for a first time McIntosh owner or as a repair project for the veteran. This amplifier is in working condition, only issue is the cracked faceplate. NO RETURNS. The unit will be shipped in the returned Fedex double boxed carton. PayPal only. Thanks for looking!
Specifications: MC 502
Power Output (minimum sine wave continuous average power output per channel from 20 to 20,000 Hz, both channels operating)
Stereo:  75 watts into 2,7 to 4 Ω ;  50 watts into 8 Ω
Which is :
14,2 volts RMS across 2,7 Ω
17,3 volts RMS cross 4 Ω
20,0 volts RMS across 8 Ω
Mono (Bridged):  150 watts into an 8 Ω
Which is : 34,6 volts RMS across 8 Ω
Output Load Impedance
Stereo :  2,7 Ω to 8 Ω
Mono:  8 Ω 9obtained by connecting across the output terminals of both channels)
Total Harmonic Distortion
Stereo :  0,02% ( max. at any power level from 250 milliwatts to rated power per channel from 20 - 20,000 Hz, both channel operating)
Mono :  0,02% (  max. at any power level from 250 milliwatts to rated power per channel from 20 - 20,000 Hz)
Intermodulation Distortion
Stereo :  0,02% (max. at any power level from 250 milliwatts to rated power per channel both channels operating for any combination of frequencies, 20 - 20,000 Hz)
Mono :  0,02% (max. at any power level from 250 milliwatts to rated power for any combination of frequencies, 20 - 20,000 Hz)
Frequency Response:
20 Hz - 20,000 Hz  +0, -0,25 dB at rated power
10 Hz - 100,000 Hz +0, -3 dB at rated power
Hum and Noise:  95 dB below rated output
Ratings Output Voltages:  25 volts for distribution lines
Damping Factor:  Greater than 50
Input Impedance:  75,000 Ω
Input Sensitivity/Impedance
Switchable:  0,75 volt or 2,5 volt/ level control provided for higher input voltges
Power Requirement:  120 Volts, 50/60 Hz ; 0,2 to 4 amperas 920 to400 watts)
Dimensions :
Front Panel (W x H) :  406 x 92 mm (16" x 3-5/8")
Chassis (W x H x D):  375 x 60 x 368 mm (14-3/4" x 2-3/8" x 14-1/2")
Finish:  Front panel is anodized gold and black with special gold/teal nomenclature illumination. Chassis is black.
Weight:  12,2 kg (27 pounds) net
Includes:
Amplifier with attached power cord
  • Last 48 hrs: 356
  • Active: 7888
  • Total: 651664
  • Last 48 hrs: 708
  • Total: 1331952
