> Classifieds > > > SVS PC13-Ultra Powered Cylinder Subwoofer
FOR SALE: SVS PC13-Ultra Powered Cylinder Subwoofer
Item #649422186
Info: SVS PC13-Ultra Powered Cylinder Subwoofer
USD $1199.00 Buy It Now
Retail Price: USD $1699.00
Payment method: Cash, Paypal
Shipping weight: 51.71 (kg) Calculate Shipping
Shipping Dimension: 50.80cm x 50.80cm x 129.54cm
Condition: 9 - Excellent (?)
Date Posted: Mar 13, 18 9:07pm (PST)
Edited: Mar 17, 18 10:18pm
About Seller: pepcmac
Huntington Beach, CA
[other classified ads]
Product Brand: SVS
Product Model: PC13 Ultra
External Feedback: pepcmac (339)
Days in System:9
Ships to: Contiguous USA
Shipping Cost:
  • Allow Local Pickup
  • Contiguous USA : $155 (standard)
Avg. Views/Day:11.56
Here's your chance to swoop up 90 pounds of pure subsonic joy! In Excellent condition this like-new SVS Subwoofer uses the Exclusive Ultra-13 Driver to deliver Brutal Output with Subtle Nuance!
An SVS-exclusive design, the Ultra-13 driver utilizes the highest quality components, custom-tooled parts, and innovative technologies to deliver an unparalleled combination of extreme output, ultra-low distortion, and exceptional linearity.
Expensive Finite Element Analysis (FEA)-optimized underhung motor technology for exceptionally low distortion.
Multi-layer flat-wound voice coil for ultra-high power handling.
Dual linear-roll spiders and stitched parabolic surround for extreme excursion capability.
Ultra-light and rigid Rohacell composite cone provides excellent transient response.
Sledge Amplification - Intelligent and Sophisticated Power
The Sledge STA-1000D amplifier is a perfect match for the Ultra-13 driver, packing 1,000 watts of power and sophisticated DSP control. Comprehensive and extensive menu options are accessed via an intuitive single-knob interface with LCD display, allowing for easy set-up and integration into any home theater or stereo system.
1000 watts RMS continuous power (3600 watts peak dynamic power).
Efficient, cool-running Class D power with 'green' standby mode.
Stereo line-level RCA and balanced (XLR) input/output connections for the ultimate in connectivity.
DSP control for the ultimate in refined behavior under all operating conditions.
Variable tuning with 20Hz, 16Hz, and Sealed settings to match any room.
Extensive menu options and digital crossover allows easy integration into any 2-channel system.
Intuitive and easy to use single knob controller with bright LCD display.
Compact Footprint, Efficient Performance and Versatile Tuning
With only a 16.5" diameter footprint, the PC13-Ultra will fit into almost any location, and no other subwoofer design offers more bass performance per square inch of floor space. Using vertical height to achieve a generous enclosure volume and deep-tuned porting, the PC13-Ultra effortlessly reproduces the deepest bass notes with stunning authority. The PC13-Ultra offers our trademark variable tuning to accommodate different size rooms and deep extension requirements. Finished in high-grade black velour fabric, this unique and elegant subwoofer will complement the most upscale d├ęcors and high-end theaters.
Small footprint fits into tight locations and is perfect for the enthusiast with limited floor space.
Slender vertical form factor results in generous enclosure volume for efficient reproduction of the deepest bass notes.
Down-firing driver provides a low center-of-gravity and excellent stability.
Wide-flared triple 3.5" ports for maximum air-flow with no artifacts.
20 Hz, 16 Hz and Sealed variable tuning accommodates all room sizes and deep extension requirements.
The Ultra Experience - Immersive and Legendary Performance
With an unmatched combination of nuance, subterranean extension, jaw-dropping slam and impact, and unerring accuracy, the legendary PC13-Ultra will positively immerse you in music and movies like never before.
This ad was originally posted on US Audio Mart US Audio Mart and the seller ships to Contiguous USA.
Subwoofer, Power Cable and Manual
