> Classifieds > > > Tannoy System 8 NFM II Near Field Studio Monitor - Single unit
EXPIRED - FOR SALE: Tannoy System 8 NFM II Near Field Studio Monitor - Single unit
Item #649400666
Info: Tannoy System 8 NFM II Near Field Studio Monitor - Single unit
CAD $200.00
Payment method: Cash, Interac/EMT
Shipping weight: 6.80 (kg) Calculate Shipping
Shipping Dimension: 22.86cm x 30.48cm x 45.72cm
Condition: 8 - Very good (?)
Date Posted: Mar 19, 18 5:43am (PST)
About Seller: dennisanstett
Waterloo, ON
[other classified ads]
Product Brand: Tannoy
Product Model: System 8 NFM II
Feedback Received: 1  See details
100% Positive Feedback
Days in System:90
Avg. Views/Day:2.86
TANNOY SYSTEM 8 NFM Series II Near Field Studio Monitor, single speaker. This speaker comes from a smoke free home and has seen very light use as a centre channel. This speaker has been magnetically shielded by Tannoy I believe when I purchased, so it weighs slightly more than a normal one. Designed for mid to near field use in recording studios, the dual concentric 8” drivers are famous for their balanced sound. In general, the sound is tight and full, the low end is very good for a pair of medium sized speakers. They are equipped with jumper rails for single wire or bi-wire use. There are no grill anymore. Beautiful piano paint finish on cabinet.
S P E C I F I C A T I O N S – S Y S T E M 8 N F M II:
Specifications System 8 NFM II
Recommended Amplifier Power: 20 to 150 watt RMS
Peak Power Handling: 200 watt
Nominal Impedance: 8 Ω
Sensitivity (2,83 volts at 1m): 93 dB
Distortion: less than 0,4% (47 Hz - 25 kHz)
Phase Response: System behaves substantially as a frequency-independent time delay
Dispersion: 90 degrees conical
Crossover Frequency: 1,7 kHz
Crossover Type: 1st order LF, cascaded 1st order HF with impedance compensation. Positive acoustic polarity
Frequency Response (±3 dB): 47 Hz - 25 kHz
Drive Unit Type: 8 inch, 2036 Dual Concentric
Cabinet Internal Volume: 18,3 litres
Cabinet Material: 30 mm MDF front baffle and back; 20,6 mm Top, bottom and sides, with energy absorbing bracing matrix and TF-1 acoustic wadding
Cabinet Finish: Velti shadow grey soft-texture finish. High pressure twin laminate in shadow grey with metallic speckled finish on top, bottom and sides.
Grille: Single piece, black acoustically transparent material over a rigid frame
Dimensions (H x W x D): 460 x 300 x 230 mm (18,1" x 11,8" x 9,1")
Weight (net): 6 kg (13.2 lb)
Additional Information:
Feb 02, 18 10:07am
Price drop from $250 to $200, thanks for looking.
Images
