> Classifieds > > > Aerial SW-12 Subwoofer -- Audiophile quality for either stereo or home theater applications
SOLD - FOR SALE: Aerial SW-12 Subwoofer -- Audiophile quality for either stereo or home theater applications
Item #649394028
Info: Aerial SW-12 Subwoofer -- Audiophile quality for either stereo or home theater applications
USD $1450.00
Retail Price: USD $4500.00
Payment method: Paypal
Shipping weight: 102.06 (kg) Calculate Shipping
Shipping Dimension: 63.50cm x 35.56cm x 58.42cm
Condition: 8 - Very good (?)
Date Posted: Nov 20, 17 1:44pm (PST)
Edited: Dec 11, 17 11:59am
About Seller: Raceone
Bloomfield Hills, MI
[other classified ads]
Product Brand: Aerial Acoustics
Product Model: SW12
Feedback Received: 7  See details
100% Positive Feedback
PayPal:
Days in System:21
Avg. Views/Day:11.10
I'm selling these speakers for the daughter of a friend who died three days ago after a long illness. So I'm not an expert on this product but I've learned a lot over the last week.
The story behind these speakers is that starting in the early 2000's, Brian started building his ultimate home audio system using the very best of everything, and he loved these speakers. However his health battle started about 10 years ago so his equipment didn't get any use since then...until this past week when I went through everything to fully sort it out.
There are two available, priced individually. Yes, although his cats used them as a scratching post, only the grill cloth was effected. They sound fantastic and are among the finest subwoofers available. Each speaker includes a manufacturer's optional steel base, sand filled, 24 lbs, with spikes.
SHIPPING NOTE: I'm willing to ship these anywhere in North America, but there are NOT manufacturer boxes available. This will require palletizing and freight shipping by truck. Fees can be quoted to your location and will also require shipping crate construction fees. Estimated at $300 for the eastern half including crates.
PRODUCT OVERVIEW
The Aerial Model SW12 is a very powerful yet relatively compact and musical subwoofer for use in the best music and home theater systems. It provides solid, quick, accurate bass flat to below 20 Hz. The woofer is a new 12.5" unit weighing 30 lbs. A huge magnet, 3" coil, and dual suspension move its strong aluminum cone linearly almost 2". Bass damping is electrically adjustable.
A high quality, high-current 400 watt amplifier and a full-featured 2-channel crossover are provided. To reduce standing wave problems and provide custom response tailoring, a parametric equalizer is included. The heavy cabinet is extensively braced and has a 2" thick front. The IR remote control is machined from solid aluminum. The SW12 system is extremely flexible. One SW12 provides satisfying high quality mono bass. Two SW12's produce more realistic stereo bass, higher levels, and better smoothness. Three SW12's add front / rear information and truly envelope the listener in bass. Large 4 or 5 channel systems are even more realistic and impressive. Unified hook-up and remote control are provided. An optional display / IR sensor is available for built-in systems.
SPECIFICATIONS Frequency Extension Flat to below 20 Hz Woofer 12.5" (318 mm) cast aluminum alloy frame driverRigid anodized aluminum cone Massive magnet structure with CNC-machined vented pole Amplifier 400 watts rms with High dynamic headroomDiscrete, fully symmetrical, high current circuitryHigh capacity dual-rail power supplyVariable damping control Filters Low Pass 30 Hz to 100 Hz continuously variable24 dB per octave slopeBypass and phase controls High Pass 40, 50, 60, 70, 80, and 100 Hz steppedSelectable 6 or 12 dB per octave slopesDiscrete precision filter topology EQ Single-band parametric with bypassCenter frequency 30 Hz to 100 HzBandwidth 0.2 to 1.5 octavesLevel ± 10 dB Remote Functions Power, level, mute, reference, damping, direct, EQ, display Power Modes Manual, music trigger, and 12 VDC trigger Connections Dual-channel or single-channel input/output capabilityLine level inputs, outputs, and high pass outputs on XLR & RCASpeaker level inputs on 5-pin DINIR input and output on 3.5 mm miniExternal IR and Display on DB-2512 VDC trigger Input Impedance 45 kÙ balanced, 10 kÙ single-ended, 1 kÙ speaker level Cabinet Minimum resonance 1" and 2" MDF wallsExtensive bracing.
Aerial SW12 Tech Specs.
Frequency Extension Flat to below 20Hz
Woofer 12.5″ (318mm) cast aluminum alloy frame driver, rigid anodized aluminum cone, massive magnet structure with CNC-machined vented pole
Amplifier 400 watts rms with < 0.05% THD, high dynamic headroom, discrete, fully symmetrical, high current circuitry, high capacity dual-rail power supply, variable damping control
Low Pass Filter 30Hz to 100Hz continuously variable, 24dB per octave slope, bypass and phase controls
High Pass Filter 40, 50, 60, 70, 80, and 100Hz stepped, selectable 6 or 12dB per octave slopes, discrete precision filter topology
EQ Single-band parametric with bypass, center frequency 30Hz to 100Hz, bandwidth 0.2 to 1.5 octaves, level ±10dB
Connections Dual-channel or single-channel input/output capability, line level inputs, outputs, and high pass outputs on XLR & RCA, speaker level inputs on 5-pin DIN, IR input and output on 3.5mm mini, external IR and Display on DB-25, 12 VDC trigger
Input Impedance 45kΩ balanced, 10kΩ single-ended, 1kΩ speaker level
Cabinet Minimum resonance 1″ and 2″ MDF walls, extensive bracing, tongue and groove joints, architectural veneers and high gloss finishes
Optional Base Rigid 24lb sand-filled steel base with spikes
Dimensions HWD 25.0 × 14.0 × 23.0″ (635 × 356 × 584mm)
Weight Each 130lbs (59kg) – 160lbs (73kg) packed
MSRP $4,500 to 5,300 depending on color plus $450 for base.
Includes:
SW12 Speaker, Steel base w/spikes, power cord, manual,
  • Last 48 hrs: 364
  • Active: 6940
  • Total: 661265
  • Last 48 hrs: 811
  • Total: 1356211
