> Classifieds > > > Serviced 1974 SONY STR-6046A Solid State 19.8 lb Stereo Receiver
SOLD - FOR SALE: Serviced 1974 SONY STR-6046A Solid State 19.8 lb Stereo Receiver
Item #649377211
Info: Serviced 1974 SONY STR-6046A Solid State 19.8 lb Stereo Receiver
CAD $280.00
Payment method: Cash, Interac/EMT
Condition: 6 - Fair (?)
Date Posted: Sep 05, 17 4:31pm (PST)
Edited: Dec 05, 17 9:34pm
About Seller: stairwaytomusic
stairwaytomusic is a premium user
WINNIPEG, MB
[other classified ads]
Feedback Received: 113  See details
100% Positive Feedback
External Feedback: damie.ca2014 (36)
PayPal:
Days in System:91
Avg. Views/Day:2.63
Don't underestimate this one... Sony made some fine receivers back in this day. This one is a beauty... looks nearly new and works perfectly. Gorgeous looks and solid performance
Specifications:
1. General
System: Transistor Receiver
Colour: 1=Silver, 2=Black: 1 (woodcase)
Pre Amplifier
Inputs: Phono MM; 2 Tape; AUX; Mic
Quadro: no
Inp. Sensitivity High Level: 250 mV
Inp. Impedance High Level: 100 kΩ
Inp. Sensitivity Phono MM: 2.5 mV
Inp. Impedance Phono MM: 47 kΩ
Frequency Response Phono MM: RIAA
Outputs: PRE OUT; REC OUT; REC/PB
Output Voltage Rec Out: 250 (RCA); 30 (DIN) mV
Impedance Rec Out: 10 (RCA); 82 (DIN) kΩ
Equalizer
Tone Controls: Bass; Treble
Filters: HIGH
Loudness: yes
Power Amplifier
Speaker Outputs: 2 x 2 Speakers; Phones
Continuous power 8Ω: 22 + 22 Watts
Dynamic Power 8Ω: 28 + 28 Watts
Frequency Response: 30-40,000 HZ
Harmonic Distortion: 0.8 % at rated output
Tuner
Display: analog
Frequency Range FM: 87.5-108 MHz
Frequency Range AM: 530-1,605 KHz
Inp. Sensitivity Mono: 1.8 (IHF); 1.4 (30 dB) μV
Frequency Response: 30-15,000 (+0/-3 dB) HZ
Harmonic Distortion: 0.3 (Mono, 400 Hz); 0.8 (Stereo) % at rated output
Separation: > 35 db
Signal/Noise Mono: 68 db
2. Physical
Dimensions in Inches: 17 x 5.7 x 13.6 (w) x (h) x (d)
Dimensions in mm: 434 x 144 x 345 (w) x (h) x (d)
Weight in lbs: 19.8 lbs
Weight in Kg: 9 Kg
  • Last 48 hrs: 314
  • Active: 3352
  • Total: 643571
  • Last 48 hrs: 531
  • Total: 1312153
