> Classifieds > > > Canary Audio Reference Two - 300B to the MAX- 80Watts of PURE Class A
SOLD - DEALER AD: Canary Audio Reference Two - 300B to the MAX- 80Watts of PURE Class A
Item #649376218
Info: Canary Audio Reference Two - 300B to the MAX- 80Watts of PURE Class A
USD $19995.00
Retail Price: USD $40000.00
Payment method: Visa, Mastercard, Cheque, Money Order, Money Wire
Shipping weight: 158.76 (kg) Calculate Shipping
Condition: 9 - Excellent (?)
Date Posted: Sep 01, 17 7:03am (PST)
Edited: Feb 06, 18 6:40am
About Seller: PBN Audio
El Cajon, CA
[other classified ads]
Feedback Received: 4  See details
100% Positive Feedback
External Feedback: pbnaudio (262)
PayPal:
Days in System:158
Avg. Views/Day:2.11
REFERENCE TWO Monoblock Amplifiers
The Best of the Best:
Canary Audio is proud to introduce the all new Reference Two Monoblock amplifiers, the first of a whole new series of high end reference audio products. The Reference Two is the result of over 15 years of experience.
Built to Withstand the Power of Music:
The REFERENCE TWO is a monoblock amplifiers with the use or sixteen (eight matched pairs) 300B triode tubes in a push pull parallel circuit. Like all of our other amplifiers, only the highest quality parts and components are used. The oversize custom wound power and output transformers are specially designed to extend the bass and highs. Each of the transformers is housed in a metal can filled with epoxy. Two independent chokes are employed for rectifier filtering on each channel. Just as important, the military grade epoxy circuit boards are designed to minimize component interaction. In addition to that, each of the 300B triode tube has a separate bias adjustment device mounted on the rear panel for convenient biasing.
The World Most Powerful 300B amplifier:
Generating power from eight pieces / four matched pairs of 300B tubes per channel. Conservatively rated with an output voltage of 80 watts RMS. The Reference Two is capable to deliver high power wattages and still maintains the clarity and delicacy of real music. Anyone who listens to them never feels the need for more wattage, all they want to do is put on more music. Perhaps the Reference Two is the most powerful 300B amplifier in the world.
Special Features:
Newly designed high voltage power supply.
The input circuit has been redesigned to be faster and more dynamic.
Balance Input is available for balanced connection.
Exclusive machined Delrin 300B tube sockets with gold plated pin receptacles.
Specially designed power meter with a custom backlite LED display.
Image Gallery
SPECIFICATIONS
Rated Power Output: 80 Watts RMS
Input Sensitivity: 0.53 Volts for full output
Input Impedance: 470,000 Ohms
Frequency Response: +/- 1 dB from 8 Hz to 80,000 Hz
Total Harmonic Distortion: 10W output: <0.07%
50W output: <0.18%
80W output: <1.0%
Signal-to-Noise Ratio: -100 dB below 80 Watts
Damping Factor: 16
Power Consumption: 380 Watts (true RMS)
Output Impedance: 4, 8 Ohm
Tube Complement (per monoblock): 8 x 300B
3 x 6SN7GTB
1 x 6SL7
Dimensions (per monoblock): 17" W x 30.5" D x 11" H
Net Weight (per monoblock): 150 lbs
Images
  • Last 48 hrs: 300
  • Active: 8125
  • Total: 643857
  • Last 48 hrs: 566
  • Total: 1312889
