> Classifieds > > > EPICURE Model ONE 2-CH 125wpc Solid State Stereo Power Amplifier Amp EPI M1
SOLD - BEST OFFER FOR: EPICURE Model ONE 2-CH 125wpc Solid State Stereo Power Amplifier Amp EPI M1
Item #649375914
Info: EPICURE Model ONE 2-CH 125wpc Solid State Stereo Power Amplifier Amp EPI M1
USD $250.00
Payment method: Paypal
Shipping weight: 27.22 (kg) Calculate Shipping
Shipping Dimension: 50.80cm x 50.80cm x 50.80cm
Condition: 7 - Good (?)
Date Posted: Aug 30, 17 10:24am (PST)
Edited: Oct 13, 17 8:09am
About Seller: NH, United States
External Feedback: hourmaker111 (635)
PayPal:
Days in System:44
Ships to: United States
Shipping Cost:
  • United States: $33.95 (standard)
Pleased to offer for sale this very rare Epicure Model One Amplifier
Works excellent!!
Some things to note, the side panel that covers the speakers terminals was missing when I received this unit. I was able to make a homemade side panel with a wooden slat to match the opposite side. This looks pretty good when looking at the unit from the front as it would be sitting in a shelf unit, but it is certainly not a perfect match for the opposite side and does not have the brass strip. The new panel slides in & out perfectly for speaker terminal access.
Overall this unit is in good condition cosmetically, there are some marks and nicks consistent with use. Some light scratches on the plexiglass front, and a small dent on the top panel. The Epicure logo lights up when powered on, I am not sure about the other lights on this unit as those lights only come on to warn of high voltage or temperature which I had no problem with during my testing.
Added 4 new rubber feet, displays very nicely and runs nice and cool!! A great rate u it for your collection.
If you have any questions or would like more pictures of this amplifier don't hesitate to send me a message!
Specifications
Dimensions: 18 1/2" x 12 1/2" x 7 1/2"
Weight: 58 lbs
RMS Power: 125 watts rms into 8 ohms,
both channels driven 20-20,000 Hz
at or below 0.2% THD or IM
(typically over 150 watts)
Total Harmonic Distortion 0.2% rated, typical below 0.05 into 8 ohms
IM Distortion 0.2% rated, typical below 0.03 into 8 ohms
Frequency Response 20 to 20k Hz, +0, -0.1 dB
10 to 100k Hz, +/- 0.5 dB
10 to 180k Hz, + 0, -3 dB
Rise Time Better than 1.5 microsecond
Damping Factor 100 or greater
Slewing Rate > 17 v/microsecond
Signal to Noise Ratio > 100 dB at full output, typical > 110 dB
Phase Response maximum deviation 15 degrees
20 - 20k Hz into 8 ohms
Input Impedance 10k ohms (input level at maximum)
Input Capacitance 50 picofarads
Input Sensitivity 1 volt for 125 watts
Stability Unconditionally stable from short to open
MSRP: 600.00 - 649.00
Built: 1973
  • Last 48 hrs: 330
  • Active: 5624
  • Total: 647052
  • Last 48 hrs: 642
  • Total: 1320569
