> Classifieds > > > AUDIO NOTE KITS TUBE Preamplifier
FOR SALE: AUDIO NOTE KITS TUBE Preamplifier
Item #649368582
Info: AUDIO NOTE KITS TUBE Preamplifier
USD $1300.00
Payment method: Cash, Paypal, Cheque, Money Order
Shipping weight: 13.61 (kg) Calculate Shipping
Shipping Dimension: 30.48cm x 45.72cm x 25.40cm
Condition: 9 - Excellent (?)
Date Posted: Jul 05, 18 6:24am (PST)
Edited: Jul 05, 18 6:25am
About Seller: misionviejo
Sterling, VA
[other classified ads]
Product Brand: Audio Note Kits
Feedback Received: 2  See details
100% Positive Feedback
External Feedback: indigowhale (430)
PayPal:
Days in System:83
Avg. Views/Day:6.52
ANK (Audio Note Kits) L2 Line stage PCB, and point-to-point wired Phono stage.
I built this pre-amplifier around the ANK L2 line stage which is the only actual ANK part in the preamp, all else acquired new from US suppliers. The phono stage is ANK design, but not ANK produced. The power supply is my own design. Too much gear built forces sale.
Preamplifier:
Only audio grade components used, absolutely no ordinary or Chinese-copy components used.
Audio Note UK Copper Foil in oil caps with 99.99% solid silver lead outs
Elna Silmic II electrolytic
Nichicon electrolytic and film capacitors
WBT Germany silver solder used
WIMA Germany capacitors
ALPS Japan volume pot
Alpha Taiwan selector switch
Dale and other precision resistors
Mallory 150 Series caps
Toroidal transformer for quiet L/C/R filtered solid-state power supply
In-rush current limiter
Fused unit
Silver in Teflon wire
CAT6 wire
Green LED pilot light
US made raw aluminum chassis
Solid milled aluminum set screw knobs
3 line level inputs
1 phono input
Lots of gain
Will be carefully packed.
Tube compliment;
ANK PCB Line stage: Hammond USA super quiet and glassy sounding 12AU7 x2
Point-to-point wired phono Stage: JAN 6189 Mil Spec and USA 12AX7
Case cover has light scratches not all visible in the photos.
A great match for any ANK power amp! ANK is a leading North American high-end factory and DIY tube audio producer.
DISCLAIMER: This unit is solid state rectified and is high voltage. It must be turned on and allowed a few seconds before any power amp is turned on--specially solid state power amps. If you are not able to follow this procedure, find a different pre-amplifier.
SHIPPING IS FREE IN THE CONTINENTAL USA
Includes:
Power cord
  • Last 48 hrs: 386
  • Active: 7194
  • Total: 652641
  • Last 48 hrs: 720
  • Total: 1334535
