> Classifieds > > > Yaqin 100B KT-88 Integrated amp upgraded Caps and Alps Black beauty volume control
SOLD - FOR SALE: Yaqin 100B KT-88 Integrated amp upgraded Caps and Alps Black beauty volume control
Item #649368045
Info: Yaqin 100B KT-88 Integrated amp upgraded Caps and Alps Black beauty volume control
USD $700.00
Payment method: Cash, Paypal
Condition: 10 - Mint (?)
Date Posted: Jan 17, 18 7:07am (PST)
Edited: Feb 01, 18 3:08pm
About Seller: NY, United States
Product Brand: Yaqin
Product Model: MS-100B
Days in System:15
Yaqin 100B KT-88 Integrated amp upgraded Caps and Alps Black beauty volume control.
I've had this for a few years and recently picked up a Cronus Magnum for an incredible deal so I'm letting this go.
Local Pick Up only
Specs:
Features User-selected amplifier modes, UT (Ultra linear) mode provides greater output power and TR (Triode) mode does smooth and rich sound. User-selected pure post-stage and integrated modes; Utilizes the audiophile capacitors and high quality metal precision resistors dedicated for audio frequency; Output transformers manufactured with Japanese silicon steel sheet and oxygen-free enameled copper and high quality lacquer, which offer a wide dynamic range at full rated output; Independent power supply for each channel. Applies special potentiometer as volume controller with low noise, and durable; Beautiful aluminum and steel heavy duty chassis, panel and bezels; Provides user adjustable bias, test points and tool to refine bias of the output tubes. Input Power : 110V - 240V AVAILABLE Output Power : ultra-linear 2x 60W (8 ohm), triode state 2x 30W (8 ohm) Tube : KT88 x 4; 6SN7 x 4; 12AX7 x 2 Input sensitivity: Integrated 0.25V Power 0.6V Frequency : 5Hz~80KHz (-2dB) Signal/Noise Ratio : ≥90dB "A Weight" Harmonic Distortion : <1.5% Input impedance: 20Kohm Consumption : 300W Load impedance: 8ohm or 4ohm Signal Inputs Level : >300mv Audio Input : TAPE,DVD,CD,TUNER Audio Output : 2 groups Input impedance : 20Kohm Weight : 30 kg Size Dimension : W: 390mm H: 190mm D: 490mm Colour : Gold Body & Dark Green Power Supply Item Includes : All the Tubes / Valve + Standard 1.5m (5 ft) Power Cord + Screw Driver
Images
  • Last 48 hrs: 321
  • Active: 3575
  • Total: 643362
  • Last 48 hrs: 517
  • Total: 1311639
