> Classifieds > > TacT Audio BOZ 216 control unit & 2200 stereo amps (two units). Beyond reproach! $17,000 MSRP
INACTIVE - FOR SALE: TacT Audio BOZ 216 control unit & 2200 stereo amps (two units). Beyond reproach! $17,000 MSRP
Item #649365477
Info: TacT Audio BOZ 216 control unit & 2200 stereo amps (two units). Beyond reproach! $17,000 MSRP
USD $4995.00
Retail Price: USD $17000.00
Shipping weight: 65.77 (kg) Calculate Shipping
Shipping Dimension: 60.96cm x 60.96cm x 35.56cm
Condition: 8 - Very good (?)
Date Posted: Dec 07, 17 3:53pm (PST)
Days in System:180
The combo you see here - one BOZ 216 control unit and two BOZ 2200 digital amplifiers were products way beyond their time. They are to a certain extend, incredibly complex units and so over engineered, there is almost none like it in the market. You can read up more from the online manual (too much to condense it here!) but to put it in real layman terms, the 216 is the preamp and also the power supply to the 2200 amps. The 216 can power up to eight 2200 amps for sixteen channel of amplification if you ever want to go the full boat on it. But in this combo, it will just power up the 2200 amps (which the previous owner used to biamp his speakers). The 2200 digital amp, to put it in real loose terms is a powered DAC. As in a DAC with the ability to drive speakers. Being that the setup is all digital, it only accepts digital inputs from a digital source. So the digital source unit will send its digital output to the 2200 where it converts (via its 24 bit/ 384 KHz DAC) and amplifies the signal where it will transmit out through its speaker binding post into your speakers. This greatly reduces the complex chain found in conventional amps. The 216 on the other hand is involved in powering up the 2200 and controlling the volume and functionality of the 2200. Each 2200 is capable of 200W in 8 ohms or 400W in 4 ohms. Both the 216 and 2200 cannot work on its own or with other brands. Each 2200 is hooked up to the 216 via its speakon connector cords (which is how the 2200 is powered up) and instructions/communications are exchanged between units via the RJ11 cables. Between the 2200 units, a second digital cable (other than the one from the digital source) is needed to "share" the incoming digital signal (via daisy link) from the digital source so both 2200 will output the same signal to the speaker. The 2200 powered DAC's display can be switched to show volume level or incoming sampling frequency which we have set separately for each 2200 in the pics. So you can either set for both to show volume level or sampling frequency.
Once all the above is done, you are ready to enjoy this groundbreaking combo. What to expect? Probably the most neutral sounding system found anywhere. And because it cuts through and simplifies how signals are converted to sound, the resolution they are capable off is incredible. It doesn't pick certain frequency range to emphasize but rather, tackles it from zero to whatever the signal extends to. All in full resolution. From its manual - "The BOZ-2200 modules are an ultra high precision D/A converters operating in PWM mode with a master clock set at a speed 2,222 times higher than the CD format, 1,024 times higher than DVD-Audio and 35 times higher than the SACD format. In contrast to conventional D/A converters, it operates at a switching voltage of more than 60 Volts, delivering the equivalent of 400 Watts per channel in 4 Ohms. All internal signal processing is performed at 96Kz." Truly some spectacular stuff in there and that is just skimming the surface on what is inside those units.
Cosmetically, there are some minor scuff marks here and there but nothing major. The 216 weighs as much as some power amps at 73 lbs and each 2200 is about 25 lbs. We don't have the original boxes but will securely pack them in two boxes for shipping - the 216 in one and the two 2200 in another. These are very hard to find pieces especially one in this condition and completeness. In terms of digital technology in audio, they are at the forefront of it all. For under $5,000 now, you are getting two very powerful amps with onboard DAC, preamp and an outboard power supply that will compete against some of the best out there at any price point.
Terms and conditions - PLEASE READ!
PRODUCT INFO: All items are fully tested and evaluated. If an item is not working properly, it will be mentioned in the listing. So read carefully. Cosmetic conditions will also be clearly laid out in the listing. But because everyone has a different standard, what is an 8/10 condition to me may be a 6/10 condition to you. So it is important you check out every picture on the listing. All pictures are of the actual item and taken just prior to listing it on eBay.
WHAT KIND OF PRODUCTS WE SELL: We are a used hifi store so everything is used. So no warranty of any kind is offered or expressed. If there is a balance factory warranty from the manufacturer, you should check with them to see if it’s transferable. See above paragraph, everything is tested prior to selling and if there is any issue, we would list it in the listing. So it’s important you read every word in our listing. Occasionally, we may get dealer demo units, NOS (New Old Stock) or dealer excess inventory. Again, you need to check with the manufacturer if they will continue to honor any kind of warranty to you.
PAYMENT INFO: PayPal payment is preferred and expected within 3 days after listing has closed. If payment is made through PAYPAL, we will ONLY ship to the address on the PAYPAL payment. NO EXCEPTIONS.
SHIPPING: Item will be shipped within 24 hours of payment clearance except late Friday afternoon, Saturday, Sunday and Public Holidays. Tracking numbers will be provided on all shipments. We ship via FEDEX and USPS with insurance and signature required. If you don't want signature required, please notify us before we ship the item. In the very rare event that an item arrives not as described in our ads, we will resolve the issue(s) with the customer to their satisfaction. Returns are not accepted for shipping damage. If somehow the item arrives damaged, the buyer will need to inform us immediately so that we can gets the claim process rolling. We will assist every way we can to get your money back. But this will be rare as we professionally pack every item that goes out to survive the rigor of shipping regardless of value. All orders will be insured and declared at full purchase value. If you want us to declare it at a lower value, you will need to fill out a form authorizing us to declare it at the amount you want us to and that you will assume all risk at the lowered value. And that includes insurance claim should the package be damaged or go missing during shipping.
RETURNS: There are absolutely no returns for any items shipped outside the United States. The only exception being vintage gear. If the listing is listed as vintage gear, no returns will be entertained for domestic or international purchases. International purchases for all other items are "as-is". The buyer assumes all cost of return shipping and handling. The only variation of this is if the item you receive is not the item you bought. In the rare event you have a change of mind (buyer's remorse) after receiving the item; we may take the item back under our buy back quote or impose a re-stocking of 20% of the original purchase price. Cost of return shipping is your responsibility. This is a case to case basis and not an outright offer to accept every and any returns back. This is why it is important to read our listing carefully. Everything and anything is described in it with all pertinent information for you to make an informed decision. If you have any questions, ASK!
DECLARED VALUE: All overseas purchases will be declared based on purchase price. NO EXCEPTION. This is because;
1) For your protection as the declared value is also the insured value.
2) eBay and PAYPAL policies dictate that all declared value must be the purchase or transacted price.
We know this may be tough in some countries because of your high duties so we will make exceptions but you need to contact us first and work out the details to complete your purchase. We will not entertain any requests after you have made the purchase and paid for it.
PARTS OR REPAIRS: All items sold as parts or repairs are NOT returnable. Please read the listing carefully and understand what you are bidding/buying before committing.
BBB
