> Classifieds > > > ESS AMT-1 Speaker grill replacement frame kit
EXPIRED - FOR SALE: ESS AMT-1 Speaker grill replacement frame kit
Item #649363650
Info: ESS AMT-1 Speaker grill replacement frame kit
USD $225.00
Payment method: Visa, Mastercard, Paypal, Cheque, Money Order
Shipping weight: 5.44 (kg) Calculate Shipping
Shipping Dimension: 25.40cm x 40.64cm x 55.88cm
Condition: 11 - New (?)
Date Posted: Jun 27, 17 2:54pm (PST)
Edited: Jul 01, 17 9:46pm
About Seller: CA, United States
Product Brand: ESS Heil
Product Model: AMT-1
Days in System:180
I will replicate frames for other speaker systems on request.
These frame kits are only for ESS AMT-1 speakers.
They are fabricated using half inch MDF cut to the original ESS AMT-1 frame dimensions, bevel and taper.
Each frame segment has a pre-installed half inch square support post. The positioning of these posts determines the size of the gap between the grill cap and the walnut cabinet at each corner. If your cabinets are worn at the corners, as mine were, the grill caps may not appear level, the grill cap may rock slightly, or the gap lines may not appear parallel. You can level the top corners of your speaker cabinets with wood filler and sand flat before painting, or you can use the 16th inch shims provided with this kit.
Choose your grill fabric and get started.
P.S. If you prefer to purchase a finished set of grills for the AMT-1 please see my other listing or contact me on this site.
My kits come with eight frame elements painted flat black, two black reflective glass-inserts for the grill tops, and eight 16th inch thick shims for fine leveling adjustments.The kit includes instructions for assembly and tips for assuring your grill fabric is tight, all the way around. Assembly is actually quite simple. You can watch and learn from my guide video on YouTube.com or contact me directly with questions, txt, email, or phone.
