> Classifieds > > > Merrill Audio Advanced Technology Labs, LLC Wide Band Cara Pre Amplifier Balanced, Dual independent
INACTIVE - DEALER AD: Merrill Audio Advanced Technology Labs, LLC Wide Band Cara Pre Amplifier Balanced, Dual independent
Item #649356909
Info: Merrill Audio Advanced Technology Labs, LLC Wide Band Cara Pre Amplifier Balanced, Dual independent
USD $3500.00
Retail Price: USD $3500.00
Condition: 11 - New (?)
Date Posted: May 25, 17 8:14am (PST)
Edited: May 25, 17 8:14am
Days in System:180
Merrill Audio will be at the LA Audio Show - Room 319 with German Physiks again. Smaller room. Visitors on the east coast come and listen. Will be playing a local Bands lp recently reviewed by Fremer. Other specials. Come hear the Fat Boy Tone arm from VPI again.
Cara Pre-amplifier is prefect for audiophiles looking for a quiet, fast pre-amplifier with multiple inputs and 4 channel outputs. This allows a biamped system or a speaker/sub combination to be control by the Cara Pre-amplifier. With a balance input and balanced output line drivers, the noise rejection on the inputs and outputs are very high and perfect for low noise systems.
Built in a steel chassis for EMI/RFI protection, the Cara pre-amplifier will bring music details out, to deliver a greater musical experience.
Pre-amplification is sometimes necessary when there is more than one source and when more than 1 output is necessary. Analog volume controls are much nicer than digital attenuation, with analog giving more details and longer decay. High attenuation capability allows the handling of high output devices like DAC and low output devices phono pre-amplifiers with moving coil cartridge. A low noise floor helps provide great music insight and better presentation.
The Cara Pre-amplifier has dual outputs with independent relative volume setting, 4 inputs to select from, an analog volume control that goes from -99db to +15db in 0.5 db steps with a 10volt operating headroom with a very low noise floor. This makes Cara an exceptional pre-amplifier with wide operational capability. Play your music with any source component and still get the best out of your whole stereo system.
Specifications:
Inputs: 4 pairs balanced inputs (2 channels x 4 set).
Outputs: 2 pairs Balanced outputs. (4 channels)
Volume and gain: -99db to +15db in 0.5db steps.
Voltage: 110/240 Factory set.
Input Max voltage: 10v
Max output Voltage: 10V
Features:
2 pairs (4 channels) outputs each can be set to independent relative volume levels.
Remote Control with Mute, off/on for remote trigger (12v, 20ma),
Cardas XLR inputs, gold plated chassis with Rhodium plate metal body, teflon insulation and silver pins.
External power supply with double fused inlet.
Large LED display with -99 to +15db control in 0.5 db steps.
Optional upgrades:
Waveform Fidelity Source Power cord
Stillpoints minirisers
Synergistic fuses – 2 required.
We appreciate you browsing. Happy Listening! removed for privacy
Or call us with any questions 415 5-MA-HiFi (415.562.4434)
Includes:
External Power Supply, connecting cable and power cord. Remote, Box and Manual.
  • Last 48 hrs: 281
  • Active: 7697
  • Total: 651814
  • Last 48 hrs: 718
  • Total: 1332449
