> Classifieds > > > Denon POA-2800 Power Amplifier - Near Mint
EXPIRED - FOR SALE: Denon POA-2800 Power Amplifier - Near Mint
Item #649351916
Info: Denon POA-2800 Power Amplifier - Near Mint
USD $475.00
Payment method: Cash, Cheque, Money Order, Money Wire
Shipping weight: 20.41 (kg) Calculate Shipping
Shipping Dimension: 45.72cm x 45.72cm x 27.94cm
Condition: 10 - Mint (?)
Date Posted: May 01, 17 3:29pm (PST)
Edited: Jul 12, 17 10:34am
About Seller: mtalbert1
Easley, SC
[other classified ads]
Product Brand: Denon
Product Model: POA 2800
Days in System:180
Avg. Views/Day:4.91
**** Note: As of 6/7 I cannot accept PayPal any longer due to their allowing fraudulent activity against my account.
I have been forced to close my account after 18 years.
For your review - A near mint condition Dual Mono Denon POA-2800.
I am the original owner and they have always been loved and care for in a smoke free home. The only reason I'm selling is life has lead me in a different direction and it is time to let things go.
This Magnificent looking Denon POA 2800 Power Amp is a monster high current stereo amplifier delivering a conservative 200 watts per channel. Amazing clarity with a total harmonic distortion rating of .002% at 8 ohms. Huge power supply. Weighs 40 pounds. Excellent bass extension down to well below audible levels. Provides a very deep sound stage. Transparent, effortless high frequencies and Solid mid-range. Signal to noise ratio 123 DB (A-weighting).
Everything working according to spec. No issues with this unit at all.
This is a rare and desirable elegantly massive Denon POA-2800 Power Amplifier from the glory days of Denon. This unit is fully functional and in excellent condition in every respect (with the minor exception of the sticky power switch mentioned earlier).
This amp sold for $800.00 in 1988 and would probably cost $2500 + today considering its build quality and specs. The sound is very neutral and clean throughout the spectrum with tightness and control in the low end being its trade mark.
Taking a close look to the workmanship and finish, you can immediately see that Denon really gave it’s all here. In true Denon tradition, it's built like a tank and is almost all metal.
With a massive power transformer this amplifier is built like they should be, with plenty of power reserves to comfortably drive almost any speaker system. It produces 200 watts per channel into 8 ohms with an incredibly low .005% total distortion. Signal to noise ratio is an amazing 123 db. There are two huge 33,000 mf (66,000 total) electrolytic caps in the power supply and a huge toroidal transformer.
This amp is truly satisfying and impressive in every way. Obvious power and clarity with amazing low end warmth. The sound stage is precise and it is extremely quiet. This amp makes good speakers sound great, and great speakers sing like never before!
Factory Specs:
Optical Class A amplifier with self-diagnostic system
Electronically protected against short circuit and overload
Rated output power: Continuous 200 W per channel min
200Watts/channel at 8 ohms from 20 Hz to 20 kHz with no more than 0.01% total harmonic distortion
330Watts/channel into 4 ohms
Dynamic music power:
450Watt/channel to 4 ohms
630Watt/channel to 2 ohms
770Watt/channel to 1 ohm
Frequency response: 1Hz - 300kHz +0, -3 dB (at 1 W)
Signal to Noise Ratio 123 dB
Connections for 2 pairs of speakers (each switchable)
Total harmonic distortion o Less than 0.002 % (-3 dB at rated output, 8 ohms)
Intermoduration distortion o Less than 0.002% (60 Hz/7 kHz: 4/1 at rated output, 8 ohms)
Power band width o 5 Hz-80 kHz (8 ohms, THD 0.03%)
Input sensitivity o 1 V * Input impedance o 25 kohms
Output impedance o 0.1 ohms (kHz) * Signal to noise ratio (A-weighted) o 123 dB
Dimensions:
Amp: 17 in (W) x 7 in (H) x 17 in (D)
Weight:
Amp: 17.5 Kg
45 lbs.
  • Last 48 hrs: 337
  • Active: 3306
  • Total: 643695
  • Last 48 hrs: 565
  • Total: 1312494
