> Classifieds > > > Audioquest Sub-3 subwoofer cable 4.5M with 36V DBS
OFF - FOR SALE: Audioquest Sub-3 subwoofer cable 4.5M with 36V DBS
Item #649349996
Info: Audioquest Sub-3 subwoofer cable 4.5M with 36V DBS
CAD $175.00
Retail Price: CAD $349.95
Payment method: Cash, Paypal, Interac/EMT
Condition: 9 - Excellent (?)
Date Posted: Jan 01, 18 3:16pm (PST)
Edited: Feb 03, 18 5:20am
About Seller: CxTurbo
Kitchener, ON
[other classified ads]
Product Brand: Audioquest
Product Model: Sub-3
Feedback Received: 3  See details
100% Positive Feedback
External Feedback: hybrid_turbo (219)
PayPal:
Days in System:180
Avg. Views/Day:0.68
** This Ad is Marked as OFF by seller and cannot be responded to. **
In like new condition original owner. Purchased from Authorized Audioquest dealer I guarantee this cable is authentic. Great cable but too short for my new set-up. This cable is 4.5M and includes 36v DBS later versions had 48V.
See below for info direct from Audioquest.
SUB-3 SUBWOOFER CABLE
Sub-3 uses three solid 6.1% Silver-Plated Long-Grain Copper conductors inside PE Air-Tubes. Solid conductors eliminate strand-interaction distortion. PE Air-Tubes minimize signal smearing caused by any solid or foam insulation. The 48V Dielectric-Bias System (DBS) almost eliminates remaining insulation-induced distortion. Three conductors ensure optimum-performance RCA plugs or XLR plugs. A 100% coverage shield ensures noise-free performance.
SOLID 6.1% SILVER-PLATED LONG-GRAIN COPPER CONDUCTORS: Silver-Plated Copper always provides superior performance for video and digital audio. Unfortunately when used for full-range analog audio, the discontinuity of silver plating over copper causes high frequencies to sound edgy and harsh. However, when used only for subwoofer frequencies, Silver-Plated Copper’s “artificial edge” actually enhances the articulation and intelligibility of low-frequency information. Do not use AudioQuest’s Silver-Plated Copper subwoofer cables for full-range audio.
POLYETHYLENE AIR-TUBE INSULATION: Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy (loss). Some of this energy is stored and then released as distortion. All of Sub-3’s conductors use PE Air-Tube Insulation because air absorbs next to no energy, and Polyethylene is low-loss and has a benign distortion profile. PE Air-Tube Insulation causes much less of the out-of-focus effect common to other materials.
DIELECTRIC-BIAS SYSTEM (DBS, US Pat #s 7,126,055 & 7,872,195 B1): All insulation slows down the signal on the conductor inside. When insulation is unbiased, it slows down parts of the signal differently, a big problem for very time-sensitive multi-octave audio. AudioQuest’s DBS creates a strong, stable electrostatic field which saturates and polarizes (organizes) the molecules of the insulation. This minimizes both energy storage in the insulation and the multiple nonlinear time-delays that occur. Sound appears from a surprisingly black background with unexpected detail and dynamic contrast. The DBS battery packs will last for years. A test button and LED allow for the occasional battery check.
TRIPLE-BALANCED GEOMETRY: The three conductors in “Triple-Balanced” Sub-3 cables ensure that whether prepared with RCA or XLR plugs, the positive and negative signals have equally low-distortion conducting paths. The 100% coverage shield is never used as an inferior conductor.
COLD-WELD SYSTEM: This plug design enables a perfect heat-free connection between cable and plug. The connection between the plug and conductors is made using AQ’s Cold-Weld System, which provides a superior connection that ensures that the structural integrity of the conductor is kept completely intact. The Cold-Weld System refers to a combination of high pressure at the point of contact and the use of copper- or silver-impregnated paste. XLR plugs are also available.
GROUNDING: Sometimes there is a hum problem unless the subwoofer and AV receiver (or surround-sound processor) are attached to each other using a separate wire. If your system has a hum problem, try attaching the little spade-lug tails to the metal chassis of the subwoofer amplifier and to the chassis of the sending component. Usually, this extra wire will not be needed.
I will ship at buyers expense. Paypal add the usual fees. EMT or Cash pickup prefered.
Includes:
Cable and all original packaging.
Images
  • Last 48 hrs: 303
  • Active: 8022
  • Total: 643967
  • Last 48 hrs: 553
  • Total: 1313180
