> Classifieds > > > Bryston 9B SST FIVE CHANNEL POWER Amplifier
SOLD - FOR SALE: Bryston 9B SST FIVE CHANNEL POWER Amplifier
Item #649349475
Info: Bryston 9B SST FIVE CHANNEL POWER Amplifier
CAD $2650.00
Retail Price: CAD $6495.00
Payment method: Cash, Paypal, Money Order
Shipping weight: 28.12 (kg) Calculate Shipping
Shipping Dimension: 44.45cm x 43.18cm x 13.34cm
Condition: 9 - Excellent (?)
Date Posted: Apr 21, 17 7:59am (PST)
Edited: Apr 23, 17 12:28pm
About Seller: ON, Canada
Product Brand: Bryston
Product Model: 9B sst
Days in System:9
LOW HOURS! Perfect working condition.
The 9BSST is a modular design 5 x 120 Watts per channel audio power amplifier.
Each channel selects a balanced or single ended input.
Each channel selects a gain of 29dB(1v), 23dB(2v) or 17dB(4v).
Each channel input may be operated inverted or non-inverted operation (0 or -180 degrees).
The 9BSST includes ‘soft start’ power control circuitry to eliminate high inrush currents when A/C power is applied.
SPECS:
Power Output
120 watts per channel into 8 ohms
200 watts per channel into 4 ohms
Gain Select and Sensitivity
29dB - 1.1Vin = 120W @ 8 Ohms (1V Position)
23dB - 2.2Vin = 120W @ 8 Ohms (2V Position)
17dB - 4.4Vin = 120W @ 8 Ohms (4V Position)
Input Impedance
50 Kohms single ended
20 Kohms balanced
Distortion (IM or THD+noise )
< 0.005% 20Hz to 20kHz at 120 watts into 8 ohms
< 0.007% 20Hz to 20kHz at 200 watts into 4 ohms
Noise
Measured with input shorted - 20Hz to 20kHz.
>110dB below rated output 29dB gain (- 73dBu)
>113dB below rated output 23dB gain (- 76dBu)
>116dB below rated output 17dB gain (- 79dBu)
Slew Rate
>60 volts per microsecond
Power Bandwidth
<1 Hz to over 100 kHz
Damping Factor
Over 500 at 20 Hz, ref. 8 ohms
Dimensions
43.2 x 13.3 x 44.5cm - 17” x 5.25” x 17.5“
Weight:
approx. 28kg - 62 lbs
Power Consumption & Heat Load
single channel 120W @ 8 ohms - 242 Watts
5 channels @ 120W @ 8 ohms - 1397 Watts
Max. Heat Dissipation 8 ohms - 2720 Btu/Hr.
single channel 200W @ 4 ohms - 422 Watts
5 channels @ 200W @ 4 ohms - 2295 Watts
Max. Heat Dissipation 4 ohms - 4420 Btu/Hr.
At Idle - 192 Watts
20 YEAR WARRANTY! Valid until 2023.
Includes:
Amplifier, Original power cable, Owners manual
