> Classifieds > > Eminence Lab12C 12" Low Frequency Transducer
INACTIVE - DEALER AD: Eminence Lab12C 12" Low Frequency Transducer
Item #649337249
Info: Eminence Lab12C 12" Low Frequency Transducer
CAD $199.00
Retail Price: CAD $229.00
Shipping weight: 10.80 (kg) Calculate Shipping
Shipping Dimension: 35.56cm x 35.56cm x 25.40cm
Condition: 11 - New (?)
Date Posted: Sep 02, 17 6:18am (PST)
Edited: Nov 21, 17 3:51pm
Days in System:90
Avg. Views/Day:1.46
Eminence Lab12C 12" Low Frequency Transducer. Great for a DIY subwoofer build.
Available for purchase only on our e-commerce website. Direct link to this item here:
https://removed for privacy/shop/eminence-lab12c-low-frequency-transducer/
Thanks for looking!
From Eminence:
-Copper voice coil on polyimide voice coil former
-Double stacked 80 oz. ferrite magnet with vented and extended core
-12 spoke die-cast aluminum basket
-Kevlar-reinforced paper cone with foam edge
-Double inverted dust cap
Nominal Diameter: 12", 304.8mm
Nominal Impedance: 4 ohms
Power: 500w rms, 1000w program
Freq. Response: 25 Hz- 120 Hz
Sensitivity: 88.9db 1w/1m
Magnet Weight: 160 oz, 4536.0 grams
Gap Height 0.37", 9.53mm
Voice Coil Diameter 2.5", 63.5mm
Recommended Enclosure Volume
- Sealed: 28.32-118.93 L, 0.80-1.00 cuft
- Vented: 39.64-141.59 L, 1.40-5.00 cuft
Overall Diameter: 12.32", 312.93mm
Baffle Hole Diameter: 0.26", 6.60mm
Number of Mounting Holes: 8
Mounting Hole Diameter: 0.26", 6.6mm
Mounting Hole BCD: 11.77", 299mm
Depth: 6.44", 164mm
Net Weight: 22.0lbs, 10.0kg
Shipping Weight: 23.8lbs, 10.8kg
Fs: 22.85 Hz
Re: 3.11 ohms
Le: 1.09 mH
Qms: 11.7
Qes: 0.34
Qts: 0.33
Vas: 128.31 L, 4.53 cuft
Vd: 659.00 cc
Cms: 0.36 mm/N
BL: 13.36 Tm
Mms: 135.6 grams
EBP: 67.29
Xmax: 13 mm
Sd: 506.7 cm2
Xlim: 22 mm
