> Classifieds > > > Yamaha Natural Sound Stereo Receiver RX-395
SOLD - FOR SALE: Yamaha Natural Sound Stereo Receiver RX-395
Item #649333623
Info: Yamaha Natural Sound Stereo Receiver RX-395
CAD $39.00
Payment method: Cash, Interac/EMT
Condition: 9 - Excellent (?)
Date Posted: Feb 14, 17 1:16pm (PST)
Edited: May 09, 17 8:00am
About Seller: gainswell
Scarborough, ON
[other classified ads]
Product Brand: Yamaha
Product Model: RX-395
Feedback Received: 24 1  See details
96.0% Positive Feedback
External Feedback: alfz (2118)
PayPal:
Days in System:84
Avg. Views/Day:5.51
Yamaha Natural Sound Stereo Receiver RX-395 in excellent condition.
PURE DIRECT SWITCH AND AMPLIFICATION CIRCUIT
When this switch is engaged, the input signal bypasses the bass, treble, loudness, and balance circuits and travels straight to the power amplifier. You can choose this short, direct path if you want maximum signal purity.
CONTINUOUSLY VARIABLE LOUDNESS CONTROL
At low volumes, the ear is less sensitive to low and high tones. A loudness switch does not solve the problem because it adjusts at only one level. Yamaha's exclusive Continuously Variable Loudness Control is the only way to fully compensate for this effect. This feature adjusts the volume while boosting or cutting the midrange to maintain proper tonal balance.
MOTOR -DRIVEN VOLUME CONTROL
Convenient remote control volume.
METAL FRONT PANEL
Prevents radio frequency interference (RFI) which degrades sound quality if component is placed near a TV or other source of RFI.
4 AUDIO AND 2A/V INPUTS
This receiver lets you hook up 4 audio components.
LINEAR DAMPING FACTOR CIRCUIT
A linear damping factor of 100 (8 ohms 20-20,000 Hz) means plenty of ability to stop the speaker cone from vibrating when the signal stops. Yamaha's circuit cancels the effect of level and frequency variations, maintaining a high, stable damping factor. The result is superior articulation of all sounds and significantly improved frequency response.
26 KEY SYSTEM REMOTE CONTROL
This means you can use the remote to control the major functions of other Yamaha components, reducing the number of remotes you need.
40 STATION RANDOM ACCESS PRESET TUNING
Preset stations can be grouped in five sets of eight, according to AM and FM, or musical genre, or any order you desire.
SLEEP TIMER
Switches unit off, after up to one hour of play.
A/B SPEAKER SELECTOR
Allows use of one or both sets of speakers.
Specifications
Minimum RMS Output Power per Channel 8 ohms, 20Hz to 20kHz, 0.04% THD = 45W 6 ohms, 20Hz to 20kHz, 0.06% THD = 48W
Dynamic Power per Channel (IHF)8/6/4/2/ ohms = 68/75/85/95W
Power Bandwidth 8 ohms, 22.5W, 0.08% THD = 10Hz to 50kHz
Damping Factor (8 ohms, 20 Hz-20 kHz) 100 or more
Input Sensitivity/ Impedance PHONO MM = 2.5mV/47k-ohms CD etc = 150mV/47k-ohms
Maximum Input Signal Level (1kHz, 0.04% THD) PHONO MM = 90mV
Output Level/ Impedance REC OUT = 150mV/470 ohms
Headphone Jack Rated Output/Impedance 0.04% THD, RL = 8 ohms = 0.45V/330 ohms
Frequency Response (20Hz to 20kHz) CD etc = 0+/-0.5dB
RIAA Equalization Deviation (20Hz to 20kHz) PHONO MM = 0+/-0.5dB
Total Harmonic Distortion (20Hz to 20kHz)PHONO MM to REC OUT (3V) = 0.02% CD etc. to SP OUT (35W/8 ohms) = 0.02%
CD Player
Signal-to-Noise Ratio (IHF-A-Network)PHONO MM (5mV Input Shorted) = 82dB CD etc. (Shorted) = 108dB
Specifications
Residual Noise (IHF-A-Network) 100uV
Channel Separation (1 kHz, Vol.-30dB)CD etc. (Input 5.1k ohms Terminated, 60dB
Tone Control Characteristics BASS Boost/cut = +/-10dB (50Hz)Turnover Frequency = 350Hz TREBLE Boost/cut = +/-10dB (20kHz)Turnover Frequency = 3.5kHz
Continuous Loudness Control -30dB (1kHz) (Level related equalization)
Turning Range 530 to 1,710 kHz
Usable Sensitivity 100uV/m
Selectivity 32dB
Image Response Ratio 40dB
Spurious Response Ratio 50dB
Harmonic Distortion (400Hz) 0.3%
Tuning Range 87.5 to 107.9MHz
50dB Quieting Sensitivity (IHF, 75 ohms)Mono = 1.55uV (15.1dBf)Stereo = 21uV (37.7dBf)
If Response Ratio 80dB
AM Suppression Ratio 55dB
Capture Ratio 1.5dB
Alternate Channel Selectivity 85dB
Harmonic Distortion (1 kHz)Mono/Stereo = 0.1/0.2%
Stereo Separation (1kHz) = 50dB
Power Supply AC120V, 60Hz
Power Consumption 120W
AC Outlets Switched x 2 = 100W max.
Dimensions (W * H * D) = 435 * 146 * 308.5mm (17-1/8" * 5-3/4" * 12-1/8")
Weight 6.5kg (14lbs 5oz.)
Includes:
Owner's Manual
Free Delivery and Setup within GTA
Similar items you might be interested in
# Caption Category Asking price Province Posted On Photo
1 FOR SALE: Yamaha Natural sound receiver RX-V673 Stereo Receivers $225.00 QC Jan 15, 2018
  • Last 48 hrs: 379
  • Active: 6057
  • Total: 616613
  • Last 48 hrs: 970
  • Total: 1243242
