> Classifieds > > > Denon AVR-3801 A/V receiver 7.1 105 w/channel multi-zone function & Denon DCM-370 5 CD Changer
EXPIRED - FOR SALE: Denon AVR-3801 A/V receiver 7.1 105 w/channel multi-zone function & Denon DCM-370 5 CD Changer
Item #649281397
Info: Denon AVR-3801 A/V receiver 7.1 105 w/channel multi-zone function & Denon DCM-370 5 CD Changer
CAD $325.00
Retail Price: CAD $2399.00
Payment method: Cash, Paypal
Condition: 10 - Mint (?)
Date Posted: Jun 18, 17 5:39pm (PST)
Edited: Jul 30, 17 7:22pm
About Seller: AndreC
Ottawa, ON
[other classified ads]
Product Brand: Denon
Product Model: AVR-3801 & DCM-370
External Feedback: andar1212 (134)
PayPal:
Days in System:180
Avg. Views/Day:1.90
FOR SALE: DENON AVR-3801 7.1 Channel A/V Surround Receiver w/105 watts per channel and Multi-zone Function
comes also with Denon DCM-370 5 Disc CD Changer with HDCD Function
Both of these items are almost brand new in the box.
I am selling them for a friend.
It's like they time-traveled!
Due to a tragedy, they were used a few times and then stored in their original boxes until now.
AVR-3801 Product Information:
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&cad=rja&uact=8&ved=0ahUKEwizyuK-_6PNAhUKNFIKHRLtDv8QFggzMAY&url=http%3A%2F%2Fassets.denon.com%2Fdocumentmaster%2Fus%2Favr3801_projectsheet.pdf&usg=AFQjCNGc2q5GeWQnNlWRHJ_3vgSFS1Usyg&sig2=18Jx8l85BNeNRE4Ow5-Bhg
***DCM-370 CD changer info is listed after the receiver info.***
The AVR-3801 is a high-performance A/V surround receiver supporting DTS-ES with 105 watts of power with equal response to each of 7 channels.
A 32-bit floating point DSP forms the heart of surround playback, performing high-speed processing on a level normally found in higher-end A/V components.
Denon has harnessed its world-renowned audio technology to fully support DTS-ES, one of the features of which is to produce a sound that envelopes the listener and moves in all directions. The AVR-3801 also provides a multi-zone function that lets you enjoy a different entertainment source in another room while other people are using the AVR-3801 in the main room. This versatile, easy-to-operate A/V receiver with superior sound quality could well be the component that meets your home entertainment requirements.
Key Features
Channels 7.1
Output Power 140 Watt
Amplifier Output Details 105 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.05% - 1 channel(s) ( center ), 105 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.05% - 2 channel(s) ( front ), 105 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.05% - 2 channel(s) ( surround ), 105 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.05% - 2 channel(s) ( surround back )
Surround Sound Effects Matrix Surround
Sound Output Type Surround Sound
Built-in Decoders DTS, DTS-ES decoder, Dolby Digital, Dolby Pro Logic
Receiver Tuner Type Digital
Receiver Tuner Bands AM/FM
Color : Black
Remote Control Type Universal remote control
Built-in Display Type Fluorescent
Dimensions
Height 6.73 in.
Width 17.09 in.
Weight 37.48 lb.
DENON DCM-370 Audiophile 5-CD Carousel Changer in mint condition.
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0ahUKEwj8gf2f-6PNAhVq0oMKHXHMDxAQFghQMAo&url=http%3A%2F%2Fassets.denon.com%2Fdocumentmaster%2Fus%2Fdcm370270_productsheet.pdf&usg=AFQjCNEK_tN10I576qqEahLeqJjkfNHtcg&sig2=V9MZGaEJXKo7Y_2_-HNMBQ
A true bargain for audiophiles! Featuring Denon's Multilevel Noise Shaping D/A converter and an advanced digital filter, the DCM-370 treats you to CD sound that's exceptionally clear, lifelike, and detailed. This capable player also has HDCD® decoding, so you can enjoy even smoother, more natural sound on thousands of HDCD-encoded discs.
Disc exchange lets you change up to 4 CDs while the 5th keeps playing. Three random play modes and 32-track programming let you keep your music sounding fresh.
Other nice touches include a remote with volume control and direct track access, a headphone jack for private listening, and a large, fluorescent front-panel display you can easily read from across the room. The coaxial digital output lets you connect an external CD-R or MiniDisc recorder for direct digital dubs, or connect to your receiver's compatible digital input.
Details:
• 5-disc carousel design
• CD Frequency Response: 2-20,000 Hz
• Signal to Noise Ratio: 112 dB
• Plays regular CDs and HDCDs
• disc exchange
• tray rotates clockwise or counter-clockwise for faster disc access
• 32-track programming
• remote with volume control and direct track access
• 3-mode random play (full random, program random, and disc sequential random)
• Digital Coaxial Output
• Standard Headphone Jack
• Multilevel Noise Shaping D/A converter
• 17-1/8" Wide x 16-7/8" Deep x 4-5/8" High
Features:
• HDCD Decoder: The DCM-370 is equipped with an HDCD decoder to ensure that you get the full benefit of HDCDs.
• Advanced Multilevel Noise Shaping DAC: Features a Multilevel Noise Shaping D/A converter. This multi-level modulation powerfully removes the adverse effects of jitter, and because it is built into the output amp, a clean analog output with suppressed high-frequency interference can be directly obtained.
• Disc Exchange: You can exchange up to 4 discs while playing a fifth; once the drawer is open, 3 CDs can be changed, then you must use the disc skip button to remove the remaining one.
• Variable Headphone and Line Outputs: The output levels are controlled by remote only (controlled using the volume +/- buttons). The line and headphone output levels are affected simultaneously, so the line output level cannot be changed without changing the headphone output level (and vice versa). If the variable line output level is changed while recording a CD from the analog outputs of this unit, the recording levels will be affected.
• Music Calendar: The player has a 16-track music calendar.
• Program Play: Up to 32 tracks can be programmed and played in any order.
• Random Play: This unit allows you to choose Full Random Play, Program Random Play, or Disc Sequential Random Play. When Full Random Play is selected, all the tracks on the loaded discs are played in random order. When Program Random Play is selected, all the programmed tracks are played.
I would prefer pick up in Ottawa, but I would consider shipping them if buyer pays shipping with insurance.
I am very reputable, having sold many items on eBay, Amazon.ca, usedOttawa and Kijiji.
here is my info.
http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=andar1212&ftab=AllFeedback
https://sellercentral.amazon.ca/gp/seller-rating/pages/performance-summary.html/ref=im_srsumprf_anav_srnavbar
Thanks for stopping by and please ask any questions.
Andre in Ottawa
  • Last 48 hrs: 322
  • Active: 7920
  • Total: 644146
  • Last 48 hrs: 586
  • Total: 1313600
