OFF - FOR SALE: ACCUPHASE P-300 AUDIOPHILE POWER AMPLIFIER
Item #175450 Info: ACCUPHASE P-300 AUDIOPHILE POWER AMPLIFIER
| Days in System: | 1107 |
| Views: | 1910 |
| Avg. Views/Day: | 1.73 |
** This Ad is Marked as OFF by seller and cannot be responded to. ** The P-300 puts out 150 watts into 8 ohms and 220 watts in 4 ohms using a direct-coupled complementary symmetrical circuit topology for every stage from input to output. Its power supply is spec'ed to produce up to 400 watts of peak power into a 4-ohm load without strain. The P-300 also has a sophisticated speaker protection circuit that engages when it senses a short circuit. This speaker protection circuit also runs a diagnostic when the amplifier is first turned on, so if the circuit senses an impedance load below 1.2 ohms it will immediately turn off the amplifier. According to Accuphase product literature the P-300 also has "closely selected parts" which translates as no electrolytic capacitors with metal film caps used even outside the direct signal path The P-300 can coast through all of these requirements without strain due to its large, heavy-duty power transformer and 2x 40.000µF filter capacitors, its all-stage push-pull circuit configuration, and well selected and thoroughly tested parts. Prepare to enjoy exciting music with the Accuphase P-300 which can deliver it. **PLEASE NOTE THE AMP DOES NOT COME WITH A WOODEN CASE". Price $800 obo or will trade for another power amp +/- cash
Includes:
Pictures are borrowed. The amp weighs 55lbs and is too heavy to remove from audio stand to take pictures. It is in excellent condition 8/10. All meter lights work and light up.
Thanks for looking.
