SOLD - FOR SALE: First Octave Audio 604 Angels Rear corner horn JBL 2266H 2408
Item #148891 Info: First Octave Audio 604 Angels Rear corner horn JBL 2266H 2408
| Asking Price: | $4500.00 |
| Acceptable payment types: |
cash, paypal, money order |
| Category: | Speakers |
| Date Posted: | Nov 07, 2009 07:06:46 AM |
| About Seller:
Username:
Landroid
Waterloo, ON
[other classified ads]
| Canuck Audio Mart: |
User Feedback : 1 |
| Days in System | 14 |
| Views: | 302 |
| Avg. Views/Day: | 21.57 |
Actions:
Give Feedback on User |
Report Problem About Ad
** This Ad is Marked as SOLD by seller and cannot be responded to. ** First Octave Audio 604 Angel rear loaded corner horns Pair Andrew Vanderkruk of bentwoodhorns new corner cabinet designed for Altec 604 Duplex coaxial drivers. This is a two way version with JBL 2266H Differential drive woofer crossed two way at 1000hz into 800hz horns with JBL 2408 1 inch throat. This is the fastest lowest bass you will hear! With a low end of 18hz at 100db,and average sensitivity of 106 db it has lower distortion than any other cabinet. Power plus, supper clean, most defined bass,deam volcals Two way dream come true! perfect time aline and phase correct. This will EAT "K" horns 24/7. Don't beleive? come and feel for your self. One reason I like The 604 Angels best is because it gets the timming of the music correct and the reproduced sound has a completly musical flow and dynamic realism that is uncanny and is not approached by any other cabinet I have heard to date. This Angel configuration has a 8 ft horn path with a flare frequency of 16hz. this low flare rate is not posible in the "K" configuration. cabinets take only 2.5 sqft floor space in a corner position provides unsurpassed coupling to room. Dimentions 56inch tall 35inch across the top wave guide 20 inch deep. 15 inch JBL2266H Differential Drive woofer 600 watts max power, 1 watt tube amp capable ,recomended power 3 to 40 watts tube power for normal listning. Call Andrew 519 746-6048 www.bentwoodhorns.com
