Search Audio & Video ClassifiedsOur FeaturesFind User
CanuckAudioMart Classifieds
User GalleriesMember Galleries DEALER ADS WELCOME - WITH CONDITIONSCanuck Audio Mart now accepts Dealer Ads for Dealers who are paying advertisers on the site.Click here for more information if you are interested. Thanks. |
Avoid Scams and Fraud: CAM is not immune to scammers and fraudsters, read here to protect yourself!
DEALER AD: Audio Space Reference 2S remote controlled tube line amplifier with 300B or 2A3 tube !!!
Outstanding Features:
Rugged stainless steel chassis
High quality EI transformer and components
Innovative tube circuitry with choke coil
Either 300B or 2A3 tube can be used
Can be fine tuned with different regulator tubes
Dual outputs (cathode follower and anode direct)
Full remote control
Switching between high and low negative feedback
Specifications:
Output Level: 2-20V P-P Max
Output Impedance 1: < 2k Ohm (300B Anode direct)
Output Impedance 2: < 5k Ohm (6SL7 Cathode follower)
Frequency Response: 10Hz – 60kHz +/- 1dB (2V P-P)
Total Harmonic Distortion: < 0.2% 20Hz – 20kHz
Input Sensitivity: 150mV
Input Impedance: 68k Ohm
Signal-to-noise Ratio: > 86dB
Channel Balance: < 0.7dB 20Hz – 20kHz
Channel Separation: > 60dB (1kHz – 3.3kHz)
Vacuum Tubes: 1 x EL34
4 x 6N9P (6SL7)
2 x 300B
Dimensions (W x H x D): 372 x 372 x 215 mm
Net Weight: 20.5kg
Please contact your local dealer for details.
