Search Audio & Video ClassifiedsOur FeaturesFind User
CanuckAudioMart Classifieds
User GalleriesMember Galleries DEALER ADS WELCOME - WITH CONDITIONSCanuck Audio Mart now accepts Dealer Ads for Dealers who are paying advertisers on the site.Click here for more information if you are interested. Thanks. |
Avoid Scams and Fraud: CAM is not immune to scammers and fraudsters, read here to protect yourself!
FOR SALE: Alpine 12" Type-R Series Subwoofer with sealed box
For sale is my excellent Alpine 12” Type-R subwoofer with heavy duty sealed box. Purchased from Number 1 Sound and used for approximately 2 years. In excellent condition, selling due to purchase of new car. This will play loud and clean, would recommend 300W+ amp for it.
Alpine Type-R subwoofers are designed with HAMR Engineering to deliver tighter, accurate bass. A multi-stage Thermal Management System and Aluminum Airflow Motor Cover provide better airflow cooling for maximum performance, With the precision-crafted SWR-1242D (12", 4ohm + 4ohm), you'll be able to handle ground-pounding, long-lasting bass and complement any system for awesome sound quality. Add another dimension to the sound, and feel your music!
Key Features:
• Frequency Response:
24Hz � 500Hz
• Kevlar Reinforced Pulp Cone
• Custom Cast Aluminum Frame with Integrated Perimeter Venting and Heat Transfer Plate
• Dual Voice Coil Design
• Mirrored Progressive Nomex � Spiders with Reinforced Layer Integrated Tinsel Leads
• Compound Radius Curve (CRC) Motor Structure
• Multi-Stage Thermal Management System
• HAMR Surround and Concealed Mount Gasket
• Aluminum Airflow Motor Cover
• Insert Push Terminals with One-sided Layout
• Designed and Engineered in the USA
Features:
Woofer
• Bumped Backplate
• Compound Radius Curve Pole Geometry
• Custom Cast Aluminum Frame with Integrated Heat Transfer Plate
• Dual Progressive Oversized Nomex� Spiders
• Dual Stacked Magnets
• Extra Length Extended Pole
• Flared Pole Vent
• High Strength Brass Voice Coil Bobbin
• Integrated Tinsel Lead Design
• Magnetically Optimized Motor Structure (Pat. Pend.)
• Oversized Parabolic Dustcap
Specifications:
General
• Diaphragm Material: Kevlar Reinforced Pulp
• Spider Material: Nomex
Power Handling
• Power Handling Capacity (Peak): 1500W
• Power Handling Capacity (RMS): 500W
Approximate Weight:
• Shipping: 21 lbs
- Alpine 12" Type R Subwoofer
- Heavy duty sealed box
- Cable if needed
