Canadian FlagAll Prices are in Canadian Dollars
Search Audio & Video Classifieds
CanuckAudioMart Classifieds
ayre's Gallery
Avoid Scams and Fraud: CAM is not immune to scammers and fraudsters, read here to protect yourself!
Home > Classifieds > Pro Audio > Alexis Multimix-16 USB 2.0 - 16 Channel Recording / Sound Reinforcement Mixer with Internal Effects
OFF - FOR SALE: Alexis Multimix-16 USB 2.0 - 16 Channel Recording / Sound Reinforcement Mixer with Internal Effects
Item #140553
Info: Alexis Multimix-16 USB 2.0 - 16 Channel Recording / Sound Reinforcement Mixer with Internal Effects
Asking Price:$500.00
Acceptable payment types: visa, mastercard, money order, money wire
Category: Pro Audio
Date Posted:Sep 06, 2009 12:38:08 PM
More Info Added on:Sep 06, 2009 12:50:35 PM
About Seller: Username: discountville
Oakville, ON
[other classified ads]
Days in System76
Avg. Views/Day:2.32
Actions: Give Feedback on User   |   View Images   |   Report Problem About Ad
** This Ad is Marked as OFF by seller and cannot be responded to. **
Total # Of Inputs
16 - Total Line Inputs
Mic/Line Inputs
16 - Balanced 1/4" TRS Phone Inputs
8 - Balanced XLR Mic Inputs
Stereo Line Inputs
4 - Stereo Paired 1/4" Phone (inputs 9,10 - 11,12 - 13,14 - 15,16)
In-Line Inputs/Returns
No
AUX Sends
2 - 1/4" TRS Phone (L/R)
AUX Returns
4 - 1/4" TRS Phone (A-L/R)(B-L/R)
Inserts
No
BUS (Group) Outputs
ALT 3/4: Balanced 1/4" TRS Phone (L/R)
2 Trk Master I/O
Main Mix Out: Balanced 1/4" TRS Phone (L/R)
ALT I/O
2-Track In/Out: Unbalanced RCA Connectors (L/R)
Monitor Outputs
CTRL RM Out: Balanced 1/4" TRS Phone (L/R)
EQ Section
High-Pass Filter: 75Hz, 18dB/octave
High Shelving: 12kHz, +/- 15dB Mid Bandpass/Band Reject: 2.5kHz, +/- 15dB
Low Shelving: 80Hz, +/- 15dB
Solo/Mute
SOLO and MUTE capability on every channel
Channel Level Control
Fader control on every channel
Trim/Gain Control
Sealed Rotary Potentiometers
Phantom Power
+48 volt switched globally
Metering
8-segment Peak LEDs
Power and Phantom Power indicator LED
Frequency Response
20Hz to 20kHz
Dynamic
Mic In Sensitivity Range: -60dBu to -10dBu nominal, +5dBu max.
Line In Sensitivity Range: -40dBu to +10dBu nominal, +25dBu max. Mic/Line Gain Range: +10 to +60dB
Signal-to-Noise Ratio
Not Specified by Manufacturer
Total Harmonic Distortion (THD)
Power Supply
18.5 VAC @ 700mA
Dimensions
13 x 3.2 x 15.2" (331 x 80 x 386mm) (WxHxD)
Weight
9.7 lbs (4.4 kg)
Images
Click above to enlarge.
Bookmark This Site
  • Last 48 hrs: 286
  • Active: 3727
  • Total: 173797
  • Last 48 hrs: 552
  • Total: 316367
Elapsed: 0.0260
