> Classifieds > > MISSION 777 POWER AMP & MISSION 776 PREAMP
EXPIRED - FOR SALE: MISSION 777 POWER AMP & MISSION 776 PREAMP
Item #103771
Info: MISSION 777 POWER AMP & MISSION 776 PREAMP
CAD $799.95
Condition: N/A (?)
Date Posted: Oct 17, 08 4:38pm (PST)
Edited: Oct 24, 08 4:36pm
About Seller: snoopwiz
Toronto, ON
[other classified ads]
Feedback Received: 29  See details
100% Positive Feedback
Days in System:30
Avg. Views/Day:267.50
RARE MISSION 777 POWER AMPLIFIER & RARE MISSION 776 PREAMPLIFIER
Here is a truly rare Mission 777 power amplifier and its matching 776 preamplifier. Both have been fully and properly tested, new batteries purchased for the pre and after a 3 day test period we have deemed everything working just as it should. We were fortunate to obtain 2 sets of these and have decided to keep one set for oursleves, to use as our pre-auction test system. We will also include the preliminary owners manual and subsequent manuals for both. The first thing you may notice about these is that not only are the both constructed of a super heavy cast aluminum plus, some of the letters in the word Mission on the front plate of the amp actually acts as a heatsink. The amp weighs 50 lbs, the pre weighs 32 lbs. When the amp is in play mode, all line AC coming into the amplifier case is cut off, ensuring no line hum pickup within the preamp unit. When the amp isnt in use, the battery is automatically put on full charge, the circuit will change over to trickle charge mode automatically when the battery is within 97% of its final charge. If you are very serious about your 2 channel audio and looking perhaps to "take it up a notch", you may want to consider this pair.
MISSION 777 AMPLIFIER
Dual Mono Construction
A True 100 WPC @ 8 ohms
175 WPC @ 4 ohms
2x 300WA Transformers
8x 15.000µF/63V- ELNA Hi-Grade Lytics, par. with RIFA capacitors
"Heavy Duty" printboards
Cast iron cabinet
Hitachi Semiconductors: 2SJ50/2SK135 MOS-FETs (alt. 2SJ55/2SK175 or
2SJ56/2S176)
THD 0.01%
Dimensions 17 1/4" Wide x 12 3/4" Deep x 3 7/8" High
Weight 32 lbs
Modular in construction
Circuit board with 2 oz of copper tracks on each side
All active components are low noise discrete type with high gain x bandwith figures
Top quality 1% metal film resistors
2 batteries (25 volts @1.5 amperes/hour capicity
2 stages of filtering through 10,000 MF
2nd stage of filtering through 2200 micorfarad caps (Decoupled by 4.7 MF polyester capacitors)
Zero line induced hum
Low impedance as seem by the amp throughout the audio spectrum
Excellent inter-channel power supply rejection
Weight 32 lbs
